Greetings DeFletchMode,
Are you familiar with this thread form a few months ago? It isn't a perfect "this is the harness" answer but if you read through it it may shed some light on things. Also, you might try to message member
ravensix as they seem to work at Ford and was part of the conversation. And, has logged in recently. A final note, I assume you are already aware but 2004 was the change over year for the 6.0's and it is good to know which version you have. I don't know if the harness is interchangeable between the early 6.0's and the rest of them.
https://www.sportsmobileforum.com/fo...d-28396-2.html
Finally, Please post what you find out. I have thought I would sleep better at night knowing I have a new harness on the shelf for when mine goes bad. I just need to bite the bullet on the money for it. I'm thinking the harnesses for 6.0's in trucks will be available for a long time but the vans not so much. And it's my understanding that the van harness is unique to all the others, again.
- Eric
