Re: Ford aux idle control power module
I have an early '04 and I had to request the AIC if I remember correctly. I keep it under the passenger seat and only plug it in when I wish to use it. I tuck the wiring harness back up under the dash. I only use Charge Protect (fast idle) mode when I'm either charging up the house battery or running the van AC. I understand that extended idling at low speed can lead to coking and turbo problems but I'm on my 3rd turbo and this one has been dismantled and cleaned once so not sure if it really makes a difference.
PatO
