Originally Posted by gahamby
I wonder where SMB buried that fuse for GMC/Chevy.
Probably the exact same place. Of all of the SMB pop tops I've seen the trim panels around the pop top are pretty much the same and all that stuff is laid out generally the same. Wherever the wire loom drops from the ceiling inside the van (sometimes front corner, sometimes rear) it sill probably be underneath the trim panel at the bottom.
I just saw a pic of this the other day digging through some stuff. Here it is, isn't a great pic but that's pretty much how the wiring is pulled through the corner of a pop top before it goes through wire loom to the roof. You can see the old inline fuse sitting in the channel.
