Originally Posted by ConnieKat
Hi,
I have a long string of small LED lights that I hope to
put over and around my sink area. Has anyone had problems.....or suggestions for installing them?
Thanks
ConnieKat
Those strip lights can typically be cut to length. If you look at the strip, there are two copper spots between every third light. Cutting at the copper spots, cut the spot in half to get the length you need.
Assuming you don't have any pre-made connectors at this point; Once you've cut the strip, solder a small drop of solder onto each copper spot, then cut and tin the end of the wire you are using to connect to it. Finally, lay the tinned wire on top of your solder/copper spot and quickly solder them together. At the end of the day, make sure the two copper spots do not have any overlap of wire or solder. These need to be two separate connections. When soldering onto the LED Strip, make sure to only hold the heat on it until you observe the solder start flowing. No need to heat the strip up any more than necessary.
Some LED strips are clearly marked + Positive and - Negative, but if in doubt use a 9V battery to determine which is which. The LED strip will only light up if polarity is correct. If you're using some small lamp cord to connect to the LED Strip, (I've found it works well) the ribbed or otherwise marked side of the cord should be used for the negative wire. Why does it matter? It only matters to the person trying to follow you some day. That person may be you, always be consistent.
Once the wire is soldered securely, place an appropriately sized piece of heat shrink over the end of the LED Strip and wire connections.
I've found that the Amazon sourced LED Lighting double sided tape doesn't always hold. In places where I'm mounting to a hard surface, such as my awning, I run a small bead of silicone down each edge of the Strip to fasten it securely. Inside, where I've mounted mine to the backside of my plywood bulkheads, I used spray adhesive on the plywood and the back of the Strip before putting them in place.
Your mileage may vary...
Good luck with your project.
