Originally Posted by Scalf77
I believe the burnt relay is the "Trailer Tow Relay, Battery Charge" The fuse listed for Trailer Tow Relay is F1.8 (it is a 40 amp fuse). It could be why the 30 amp relay sacrificed itself. I suspect that it is possible that SMB tapped into this relay to run your lights. It should supply power when running.
Greg
That's EXACTLY what that burned relay is. There are 4 power taps to the other side of that fuse/relay, so I would assume SMB pulled power from one of those taps for the spots
#1 under hood / driver side / on main loom / close to water reservoir.
#2 driver side kick panel, on the trailer brake controller harness.
#3 B pillar, close to the floor, right behind seat-belt.
#4 Just before rear trailer harness, on frame rail.
I know that wiring inside out, I've studied it enough...
BTW, #1 is right next to the High Idle wire loom. Not sure if that's any relation to your high idle not working or not.
But pulling from #2 makes more sense considering inside switch and hopefully another relay and fuse.
