Old 05-25-2021, 08:46 PM   #11
Thanks I do have one and had left it home charging on that trip. Oops.
Clarkboulder is offline   Reply With Quote
Old 05-25-2021, 08:51 PM   #12
Thanks Great info Makes a lot of sense. Might just leave the panels home. 29lbs and bulky is just not worth the value brought to the camp site.
The flat(ish) rectangular portion of my hood is 55'x20". Seemed like a good surface but I see that it may not be worth it according to your numbers. I have not used idling yet to charge as I sort of detest the idea but it may be something I need to get used to...occasionally. Thanks
Old 05-25-2021, 08:54 PM   #13
DIY Lithium battery?
Old 05-25-2021, 09:58 PM   #14
simplesez's Avatar
Originally Posted by 86Scotty View Post
Yep, I'm blissfully out of touch as usual.
#tunedouttotrends
Old 05-26-2021, 05:53 AM   #15
Yes. Check out electric car parts.com out of utah. I built a 4800 watt hour battery for my van using their fortune 100 amp hour cells and a bms from overkill solar. Pretty easy and it powers the loads in our van easily. We use the van in the winter here in CO. My other half is terrified of a chill so it will run a heating blanket all night in addition to the diesel heater. It also runs the coffee maker and microwave and electric cooler. A three day weekend of maximum use is going to use about half the capacity of my battery in those conditions. I built a much bigger battery for my travel trailer. 13000 watt hours. I can tell you more about the source of the cells (direct from China) but for reference it cost the same to build as the battery in my van.
cotrailhead is offline   Reply With Quote
Old 05-26-2021, 08:15 AM   #16
Thanks COTRAILHEAD! That sounds like a good option although I am a noob to all of this so I have a lot to learn. (I only know bikes!)
How do you initially charge those batteries? Is that charged via engine or solar or electric hook up?
I’d love to learn how this could replace the generator (as it seems it could) and how and what converting to this option looks like. I just have no idea where to start with it. I only ever really want to power the microwave and an occasional induction hot plate or other basic appliance or plug in lights. Lugging around a generator seems silly for that as does the heavy solar panels just to top off the two house AGM batteries. That combo is over 160lbs.
Old 05-26-2021, 02:05 PM   #17
FYI I have just been doing a little research on the cheapo DIY LiFePO4 batteries.
If you want to go the cheapest for DIY LiFePO4 check out Will Prowse's channel. In the link below he tests a 280 Ah setup.
The cells are $416 (including shipping and tax) and the BMS can be anywhere from $150-$200 depending upon features.
So for LiFePO4 you are getting 0.8*280=224 Amp-Hr for $600 ish or $2.7 / amp-Hr
Compared to cheapest deep cycle lead acid 80 amp-hr / $100 which is equivalent to only $100/40 amp-hr
$2.5 / amp-hr .
Super Start Marine #24DCMJ
https://www.oreillyauto.com/detail/c...per-duty?pos=5
So capacity wise these are as cheap as lead-acid (non-AGM) but with much higher rated charge/discharge cycles. So the lifetime will be much longer. The size and increased charging rates are the know benefits as well.
I think it is recommended that you go to a 24V system if you want anything larger than this for running microwaves and induction ovens. The cable sizes just get too large.
This is somewhat older but gives a good overview.
The main thing that I did not see covered in either video is the thermal control of the battery pack. Like most things, the batteries will generally work best in temperature-controlled conditions like 20 degC. But for Lithium you have low-temperature shutoff requirements; they do not like to freeze. They can tolerate high temperatures even into the 115 degF range. See some details here.
https://batteryuniversity.com/learn/...w_temperatures
You will want to get an electric heating pad.
These are easy solutions for heating. All you need is a switch (possibly a relay but it is only 5 amps) and the thing controls itself.
Facon 7-1/4" x 25" RV Water Tank Heater Pad with Automatic Thermostat 12V DC
https://www.ebay.com/itm/30172428306...pid=1682217542
Whether you want to do any cooling will depend on battery size. Pulling 5 amps off of a 100 amp-hr battery is pushing it for an all July 4th all-day cooling scenario. In this case, I would at least run fans ( for example I am putting two 50mm/0.1 amp fans on my charge controller; two are for redundancy). For example, I have a wireless router mounted in a storage room that is exposed to the outside temperatures here in Tucson. I noticed that the heat sink was getting pretty warm and I left the case open and used a 5V USB fan to push air over the heat sink. It stays much cooler just with the forced air flow.
If you have a large battery and then a Peltier like this (4.5 A rated) might be a good idea if you can arrange a heat sink and cooling fan in the battery enclosure. So this has a comparable power diip[nation to the heater. You would need some type of thermal switch.
Teyleten Robot TEC1-12706 12V 60W Heatsink Thermoelectric Cooler Cooling Peltier Plate Module (5pcs)
https://www.amazon.com/dp/B07YZQFH65...NsaWNrPXRydWU=
This is basically how you configure a Peltier with fans to move out the heat and move the cold.
WiMas DIY Peltier Cooler Kit 12V Semiconductor Thermoelectric Cooler Peltier Cooling System TEC1-12706 Peltier Heatsink Module kit+Fan
https://www.amazon.com/dp/B07X6DX97Y...dDbGljaz10cnVl
These things are cheap and seem to work well.
2 Pieces DC 12V Electronic Temperature Controller Programmable -50 to 110 ℃ Heating/ Cooling Thermostat Control Switch Module, NTC Waterproof Sensor Probe, Dual Color LED Display Monitor
https://www.amazon.com/Electronic-Te...2059403&sr=8-5
Old 05-27-2021, 01:36 PM   #18
I "bit the bullet" and ordered the LiFe cells and BMS from Ali-Express for a pair of DIY 100 Amp-hr batteries.
https://www.sportsmobileforum.com/fo...ild-28632.html
Old 05-30-2021, 04:39 PM   #19
moorefc's Avatar
On the hood mounted solar cells, besides the heat issue may be a reflection issue while driving....ouch..
And for diy lithium conversion there are a lot of posts, but you need
batt cells
BMS
(for an E350) a DC-DC converter
Wiring etc.
The dc dc can be expensive $200-400 (there are less expensive hacks, but...)
BMS is ~$100 BMS discharge rates limit one to ~1.5Kw inverter unless going to a $$$ BMS.
Cells are quoted above
It is quite a project when you get into it, but does have huge capacity potential.
It also is electrically and thermally complicated (ie reliability) compared to heavy metal lead acid alternator technology. I have been playing with but am on the fence re installing LiFePo4 in the van...
diysolarforum.com/ has lots of information and opinions on this option....Will Prowse (video above) is definitely entertaining and has a big following...
Pac NW and warmer places
2006 E350 EB Elect Top 2WD
moorefc is offline   Reply With Quote
Old 05-30-2021, 06:25 PM   #20
Wiring etc.
Yea this weekend I have been coming to grips with switching from lead-acid deep cell to LiFePO4. My C/10 charging rate setup goes out the window with LiFePO4. I just bought the Renogy 40 amp DC to DC for $169 no tax-free shipping.
https://www.renogy.com/12v-dc-to-dc-...ttery-charger/
This morning dealing with the alternator overheating issues. I'm working on building up a double rocker ON-OFF-ON to control 40A/20A with a temp sense at the alternator to shut DC-DC charger on thermal overload. Tentatively 80 DegC but will have to do some testing to finalize that.
The tech is somewhat mature and there are multiple commercial and DIY alternatives. People are succeeding even if most have some issues (very understandable). As an EE this does not bother me as much. I can also tell you I have wasted just as much time with "known good " solutions as DIY. At least with DIY you generally know what you are dealing with. When a vendor is protecting their reputation by not telling you about "issues" you can waste even more time. In contrast, with DIY you have hundreds of people posting their results and problems and usually, if you scan this you can avoid their problems.
Yes been there and scanning threads which is where I'm finding the gotchas to avoid.
Behemoth
Besags
Agnes
ranchero
