No, I did not save the AS-Build-Data and did not really looked which bytes had been changed. Sorry.
Did the dark car mode switched off the internal lights to come on on your car?
I remember that I first enabled dark car and did not notice the "Welcome Light" field at the first moment. A couple of days later I found the "welcome light" switch in forescan.
On you picture there is the WElcome Light" field missing which is available on my -> see picture :
It might be a problem of your Adapter? Or you model year?
Here is another good help :
FORScan - Modify Module As-Built Data (Detailed)
And here :
https://forscan.org/forum/viewtopic.php?t=4393
