Hello, I know this is a Sportsmobile forum, but folks also seem to have knowledge of the ford e-series vans in general, so was hoping I could get some thoughts on my solar charge controller and assorted other bits to set up my solar system in my unconverted 2005 e-350 van.
Specifically, I'm wondering if there is room on the passenger's side panel walls (behind the barn doors) or on the driver's side panel walls (middle of the van to the back) to embed the components I need into the wall between the metal skin and the stock plastic panels. I have not taken the panels off to inspect yet as it involves removing the bench seats also and they are bulky (require 2 people).
I've got a Victron MPPT solar charge controller and a Victron Orion combiner (so I can charge from solar or alternator) which need to be mounted to piece of plywood secured to the walls somehow. I would also have a couple of buss bars, ATO blade fuse panel and probably a some other small bits. I would set up a couple of connection points in the wall also for panels that include lighter port and USB ports (and a voltage gauge) so I have some charging points for kid's electronics and the ARB fridge/freezer we travel with.
Wanted to see if any of the forum experts had some thoughts on placement before I go disassembling the interior plastic panels. The goal is to have the components close to each other but protected so was thinking of embedding everything in the panels with cutouts for access. Appreciate any thoughts from the group!!
