Old 09-03-2024, 08:45 PM   #1
Intertek 4007244 CO Detector Replacement
She's been installed since 2016 - definitely time for a new one. I searched the forums and it's a little weird nothing came up on this?
Love some recommendations on "newer" tech yet same size units. Thanks all!
2002 E350 7.3 Sportsmobile
FrontmanAdventures is offline   Reply With Quote
Old 09-04-2024, 06:14 AM   #2
I had same issue when replacing mine - combo CO2 and propane detector - had to make a back plate using carbon fiber sheet as original hole was slightly larger than the detector dimensions - looks good with my gray fuzzy material from SMB Fresno -
Old 09-04-2024, 09:20 AM   #3
Twoxentrix's Avatar
Scalf77 shared this Thread with the Group (has a backing plate for a clean looking install):
https://www.sportsmobileforum.com/fo...tor-31253.html
This is the one I used on my last swap and no issues with the fit (Safety Alert Model 35-742):
https://www.amazon.com/Safe-T-Alert-...71&sr=8-1&th=1
