Okay I know this is probably an all-too-often asked question but want to have a few real-life user experiences with those who've used inverters with single battery vehicles, IOW no house or second battery bank.
Running a stock 2005 E-350 with 5.4, factory stock 130 amp alternator recently rebuilt due failed internal diodes (at 177K miles) along with an NAPA
Legend battery rated at 850/1045 CCA. FWIW my alternator rebuilder says we could upgrade mine to 160 amp output if that would be useful for my anticipated use.
Adding an inverter (minimum of 2500 Watts) to my van would be an
occasional use device, it would power nothing more than a Milwaukee 120 VAC Sawzall tool, it draws about 8 amps under a full load. Honestly it would never ever be used for any other reasons. For some reason Milwaukee rates this tool at 13 amps but so far I've not seen it peak much above those 8 amps.
Currently (no pun intended
) this inverter and tool would be used
maybe once a month if that. It would be used about 20 minutes, engine running the whole time and after the job was finished to replenish any higher-than-usual amp draw.
I would connect it to the stock starter battery with heavy duty alligator clamps and probably 1/0 cables extending far enough to sit the inverter on the ground while running an extension cord to my work. I work on big trucks so might occasionally be able to tap into their massive chassis multi-battery arrays, the truck engine running the whole time then as well too. It would be stowed away when not in use, possibly in the future a fixed well ventilated location with properly run cables running to the factory alternator, quite possibly the starter's positive terminal.
So then my questions become would my anticipated inverter use in any way damage or shorten the chassis battery life? If it would or its installation would require too much more than I've outlined it would easier to buy a Honda EU2200i generator---money isn't the concern here. My resistance to the generator is it would be vastly under utilized and I don't care to carry fuel inside my van.
There would also be a minor storage space concern BUT if the inverter use would potentially leave me stranded with a failed battery or over-stressed alternator it'll be a no-go.
So looking for any real world experiences with this sort of set up as I've tried describing. Thanks in advance and it's 100% okay to play Devil's advocate for me----we're just spit ballin' so far.
