Old 01-14-2021, 01:26 PM   #21
Lewgillett- it was the start batteries that were replaced. I did not know the van had 2 start batteries until I took one out. I am shopping for a house battery now that will fit in the bracket. I just want to get one so I can start using the van and fixing all the electrical things going on. I'll upgrade the batteries and bracket later. I have learned so much in the last week.
Berta is offline   Reply With Quote
Old 01-14-2021, 01:28 PM   #22
Courtney, where did you get the carbon monoxide sensor replacement? I'm looking for one now.
Old 01-14-2021, 01:29 PM   #23
simplesez's Avatar
Amazon has them.
PDX RV is another good resource
Old 01-14-2021, 01:54 PM   #24
I got it direct from sportsmobile so it would be the exact size to fit in. All the replacements I found were physically smaller and I would have had to patch in the larger hole and carpet as mine was along a kickboard just off the floor...
Courtney is offline   Reply With Quote
Old 01-14-2021, 02:57 PM   #25
vandiesel's Avatar
Originally Posted by simplesez View Post
Amazon has them.
Just put my amazon replacement in today. Fit in same spot as old original one.
Old 01-14-2021, 04:22 PM   #26
Your house battery will never recover from getting that low. It will show voltages of 13.X after charging but it won't last more than a couple of hours. You need to replace it. Typical things that will charge it is leaving the inverter or converter ON when there is no shore power or solar in excess of 2 amps. You have jumped in at the deep end so get the Manual from the SMB web site.
vlagat is offline   Reply With Quote
Old 01-27-2021, 01:57 PM   #27
I want to say thanks to everyone for your help and suggestions. I'm getting the hang of how the van's electrical system is put together.
I replaced the house battery with another D4 AGM because it fit and was available. It seems to be working well. I will probably upgrade the house battery in the future. I read through the suggestions and research that you shared. Very educational. I will use them when the time comes to upgrade. Thanks!
