Magnum settings have me easily confused
I have a Magnum 2000w charger/inverter with the remote panel. When on shore charge, it will not float over 13.2 nor do I see going into absorb. Often it will just state FULL CHARGE and the voltage only reads in the 12.7 to 12.4 range. I can get to absorb phase and 14.4 if I shut it off for a day or two then turn on the power again.
I think Magnum thinks lower voltage is better for battery life??? Lifeline 4D AGM and they call for the 13.8 float charge. Thinking the lack of higher charge will shorten the life on this battery. It does seem to lose more charge overnight with only a fridge and sometimes the furnace running.
How can I adjust the charging profile to get the higher voltage? Tripp Lite in old van had no problem giving the higher charge. Puzzled.
