Originally Posted by Scalf77
My assumption is that he is seeing the lower voltages when the alternator is closer to idle. It really depends on what additional electrical loads one is running at the time this is happening. Remember the The surepower and B/S ACR would monitor voltage, if the voltage dropped below 12.8 volts the units would disconnect, thus reducing any load coming from the "house system".
As mentioned by greg, there can be a smart relay in the mix as well for an SMB
This is something I keep forgetting about because I don't have a "Surepower or equivalent "smart relay". If this is in series with the DC-DC then it is an integral part of the shutdown (low Chassis charging) behavior.
What worries me about the DC_DC behavior of the renogy for sure and others that are alike is that they boost voltage all the way down to like 8V (see spec sheet attached). What exactly happens between the DC to DC trying to extract more power from the alternator/battery package that is available is kind of complex.
If the alternator current maxes out, the output voltage probably drops to the battery terminal voltage and then you are just pulling current from the battery in excess of what the alternator can provide. In this case, the ACR would stop any such nonsense from occurring.
Since I don't have an ACR I would want to manage the charging control manually. Alternatively, I have looked at automatic thermal shutdown or even more elaborately a managed thermal control (using a microcontroller).
The simple way to do this is in the figure attached which uses an inexpensive thermal switch.
The idea is that The red rocker switch lights RED when with 40A (UP) or 20A (DWN) off-center positions (used to control D+ and LC on the renogy). The voltmeter can be seen from the driver's seat and monitors the HAUS battery voltage.
The relay is there to cut out the controls and turn off the DC-DC completely if the thermal switch closes. I was looking at the 80 degC rated switch but these are not that precise and have a pretty wide range so that may need some adjustment.
My plan was to just take a strip of brass/copper and wrap it around the temp switch and drill a hole (in the strip) and use a mounting screw on the back of the alternator. One wire would be grounded at the alternator case mount and then a single switched ground wire would be run to the cockpit where the relay and switches are.
While optional, I added another RED warning light to indicate the DC-DC was shut off in an over temp mode.
Anyhow food for thought for how to best control the DC to DC . There is a thread somewhere on an RV forum that describes various ways to control the renogy 40A DC-DC using voltage control with an off-the-shelf controller board. Ultimately my conclusion is that this is all indirect control and you still need some type of thermal control coupled with some sort of voltage which is why I also started developing a microcontroller solution with a display.
