I just built an 2000w Xantrex inverter setup in my cargo trailer and just used plastic boxes for the remote, voltmeter and fuse gear. The Dremel worked OK cutting the plastic cover to fit the remote but a jig or saber saw might even do a better job. You just got to be a careful guiding the cut with the Dremel tool. For the holes I just used a step drill bit. I'd think wood might be easier to work with if it's thin enough.
Not bad Rob. I haven't been out to off road for over a year but getting my van ready. I need two 4D batteries so after that hopefully I will get back into the pines.
When I needed custom mounting plates or boxes I designed what I needed and a friend 3D printed them. Attached are photos of two examples. That way you get exactly what you want.
Jim
Nice dude
As it happens, i was in Michales Art Supply today
they have the perfect box, $7 !
