I believe the proper place to make the changes is under the VSS menu, which I don't think is available on AE, only on Ford IDS. Basically, you use a Tire-height/gear ratio table to input a revs/mile ratio. Some other-than-stock tire sizes can be entered depending on gear ratio, however that range is limited. I was able to adjust for 4.30 gears, because I had 265 tires. But I couldn't adjust for 4.56 gears. I ended up buying a signal converter box, but I've never gotten around to installing it.
