Old 11-08-2012, 06:37 PM   #1
BrianW's Avatar
Opinion wanted on this solar panel
Hi all,
A local guy is selling a number of these "Trina" 240-watt solar panels as refurbs at $120 each. I was thinking of getting one for my SMB, but honestly don't know the first thing about spec'ing a panel, other than what I've read on the forums (consensus seems to be to get at 125 watts).
Any advice would be great. Here's a link to the panels: http://www.solarelectricsupply.com/Sola ... 0DA05.html
Thanks!
Old 11-08-2012, 07:51 PM   #2
Re: Opinion wanted on this solar panel
You might ask the seller if it has a warranty when installed on a RV. I'd also want to know if it can be tied into a RV solar controller...there is no voltage specs (that I saw) Other issues would be how to mount it. Seems the RV type panels are designed to be bolted to a vehicle. That said maybe its a good deal???
Old 11-08-2012, 09:01 PM   #3
Tapatio's Avatar
That is a high voltage panel and is not compatible with RV 12v solar controllers. I have a Solar Boost 2000e and the recommended max open voltage (VOC) is 24v. That panel puts out 37.5 VOC.
All solar panels are made for outdoor use so I wouldn't worry too much about RV ratings, especially if you can find something for $125, just my opinion.
Solar Boost 2000e data sheet
http://www.blueskyenergyinc.com/uplo...Edatasheet.pdf
Callsign KK6GIY
Old 11-09-2012, 07:48 AM   #4
BrianW's Avatar
Thanks guys! Amps, volts and all that gets me confused sometimes. I'm pretty good with wiring stuff up, though.
I also found a 24v panel locally on Craiglist for around the same price, so maybe that would be a better war to go (or, of course, a 12v one).
Old 11-09-2012, 10:44 AM   #5
Actually at one time Kyocera was one of the few companies that offered a warranty on their 135 watt panels if mounted on something mobile. Looks like nobody (at least I couldn't find one) will warranty them now if installed on a vehicle or boat. Of course you don't have to tell them where they're mounted One thing about glass panels is they have been time tested but they can break. I shattered one of mine but hopefully that won't happen again.
I wish they would sell semi flexible panels at a reasonable cost. Unfortunately my flat walkable Solars did not last very long and was a huge mistake money wise on my part. Everything semi flexible I've seen on the market has a beaucoup price.
If your goal is to just keep your batteries up and charged for maintenance, a small 80 watt panel with a good mppt controller will do fine but having the ability to supply a positive charge to your house battery system depends on your daytime load usage and how large and how deep you've taken down the battery system. Seems that a 130w panel is a reasonable size for a SMB when comparing a cost to preformance value. YMMV I have twin 135's on my van.
Old 11-09-2012, 02:51 PM   #6
BrianW's Avatar
I'm mainly looking for long-term battery maintenance while parked in my driveway to keep the batteries charged up, as I can't keep it plugged in all the time. My driveway gets full sun for over half the day, even in winter. I figure I either invest in solar or keep investing in replacing dead batteries! The charging/power while actually camping is secondary, although also very desired.
Old 11-09-2012, 03:28 PM   #7
I'd at least prepare for adding to your array if you go small. Wire for it and purchase a large enough controller to handle future needs. It's nice to be able to supply the refrigerator and still have some power left over while the van sits.
