Old 03-18-2023, 03:21 PM   #1
Portable 12v air compressor for inflating tires
I know that letting air out of our 4x4 tires when in sand or soft surface is sometime advisable and I'm wondering how to re-inflate the tires when back on more solid surface out in a forest somewhere. Anyone aware of a 12v portable air compressor to plug into a cigarette lighter socket with a long cord or hose that will allow filing tires to at least 60 lbs? Or is there a compressor already on my 2006 E350 4x4 that I haven't noticed? Or, any other solution? Thanks
dogsandcats is offline   Reply With Quote
Old 03-18-2023, 03:51 PM   #2
Steve C's Avatar
You've chosen a pretty common question that gets asked here. Instead of looking up multiple threads and posting them for you. Copy the following search directly into Google and it will show you where to find the threads already in existence. You just have to toggle down past the adds.
Air compressor site:sportsmobileforum.com
FWIW, after reading through all the various threads - I purchased an ARB single pump and it has worked out well for me. Not the fastest and not the slowest and certainly not the cheapest.
Cheers! -steve-
2001 Sportsmobile RB50 7.3
West Central Mountains, Idaho
Steve C is offline   Reply With Quote
Old 03-18-2023, 03:54 PM   #3
Twoxentrix's Avatar
If you have a 2006 6.0 Van, look under the frame rail area on the drivers side (I've heard of a couple mounted under passenger side - never seen this myself through). If Sportsmobile installed one it's more than likely an Outback Extreme.
There are plenty of 12v air compressors that work either off their own batteries and/or the cig lighter socket, but I don't think you'll be impressed with them. Suggest you look at some portable compressors that are more robust (Preferably one that has 100% duty cycle):
Extreme Outback
Viair
Smittybilt
ARB
Really boils down to how much you plan on using it - more demand should steer you towards better quality & reliability.
Old 03-18-2023, 07:32 PM   #4
the harbor freight 12 volt air compressor is small and you can plug it into the cigarette plug (cost about 40 dollars) but it is very slow for large tire.
Smittybilt has two models the the 2080 (30 amps) and the giant 2081(45 amps) these are more expensive in the 200 dollar range but will fill up your tire quickly, they connect directly to the battery and you need the engine running for best results.
There are similar compressors like the smittybilt from different manufactures that look the same. Masterflow and Gobege, these are in the 160 dollar range.
I have the harbor freight one and also the 30 and 45 amp models. The 30 amp one is the one I been using for over 10 years and has worked great. The harbor freight I rarely used. I bought the 45 amp one to replace the 30 amps one, but its overkill for my astrovan tires. Its a very large inflator that takes up alot of space, it would be a great inflator for large tires. I also recommend the Jaco tire inflator chuck, they aint cheap at 25 dollars but it makes the job of inflating the tires go quickly without losing any air.
30 amp inflator
jonyjoe101 is offline   Reply With Quote
