Wow......that's unfortunate.....do you still have the van? ..or at least the battery pack?
..I was hoping you might chime in, I remember that you built a pack.
I just read your thread....impressive build!
So my main motivation for Lithium was I did not trust most of the commercial offerings that had none of the mechanical features for compression, cooling, and vibration. Additionally, I wanted to do a small project in anticipation of doing battery-backed-up solar for the house. I bought 32 of the 280 Amp-Hr EVE cells for a 560 Amp-Hr 48V battery.
You have a very clean design for that 7" tight space. Mine ended up being about a 10" width inside of the RB (over the driver's wheel well). In the pictures, you will see that i had a back bed area supported on 3/4" plywood frame going across the van vs length-wise.
As I progressed I realized It would save a lot of space if I could consolidate components directly on top of the battery. In the last picture, you can see I have all the power and ground distribution from copper bus bars going to all the external devices 9solart changer, DC-DC charger, inverter etc. This is not particularly modular from the battery standard point, but it is quite compact.
I think we discussed the issue of Load Dump and putting a LA battery in parallel with the Lithium. I explored in detail some electronics Load Dump protection, but in the end, the best solution was the LA battery. So the volt meter and red pushbutton you see are for voltage equalization when first connecting the LA to the lithium. The battery fits into the battery box although it is too tall. But adding a 2" spacer for the lid will work for this rear location. If you have these battery boxes mounted on the passenger side under the step there is not enough room for the extra 2".
The LA battery is for the 800 lbs Lift so it is an infrequent duty and a good match/secondary role for the load dump protection of the Lithium.
The van lift has a single battery box mounted in the rear. I ended up buying a high-quality used backup AGM battery that is a perfect solution for the lift and would work well with the lithium. I'm still not sure where they will go but i will try and consider having an option for adding a second of a similar form factor (albeit without the extra external components). For now, this is what you would call a "stretch goal" and only be necessary if I installed a chinee roof air unit.
The 200Amp-Hr battery consisted of 8 100 Amp-hr cells that were cheap and bloated and I got 30% off of that price. So in that previous post, I document a balancing process that pairs (parallel) cells to achieve might levels of cell pair matching. It is at least as good as Grade A selected cells.
