Old 04-07-2020, 07:07 PM   #1
Prosine 2.0 in 2006 E350 6.0 Battery not Charging
Prosine 2.0 in 2006 E350 6.0 Battery not Charging the House batteries.
Shows AC in 125 V Charging Light does not go on just goes to Standby but in the display it says the Charger is Enabled but voltage is down to 10.2 V
What should look for
Ed from Nebraska
ebrogie is offline   Reply With Quote
Old 04-08-2020, 08:45 AM   #2
When you did your output test did you disconnect the load (house batteries) from the converter?
Is there a reset button? If not try disconnecting the power and see if on the reboot it heals itself.
Are the charging settings adjustable? If so check those settings. Finally check for a good ground.
Old 04-08-2020, 09:01 AM   #3
early this morning I shut off the inverter/charger for a few seconds and rebooted that seemed to work and the charging light kicked on
thanks very much we will see if that works over time
Ed
