Redoing the 12v on a 93. Anyone have the diagram?
Just wondering if anyone has the diagram / manual pages for the 12v system on a 93 Sportsmobile. I know the house battery is charged via the battery isolator under the hood, I was expecting to find that behind the battery on the drivers side, but nope. It is behind the passenger side headlight and is MUCH larger than I expected. Wiring between there and the electrical compartment should already be 8 gauge, and have the 50 amp breaker in line, so I just need to bypass the isolator, and whatever the cable attaches to in the electrical compartment, set it up for the Anderson connector for my DC to DC charger DC charging circuit (It is also an MPPT controller.
I also need to see how this ties into the 12v output side of things. I eed to tie my new battery bank into the 12v output.
I see the fuse panel on mine, but it looks like there is very little there, maybe 3 fuses populated. I suspect I will be tracing wires, and it is still hot in Texas unless I pop the top, open all the doors and windows it is just intolerable inside the van...
FWIW, I am trying to integrate the following.
2 @ Dokio 300w portable panels via a custom Anderson connected Y cable.
2 @ Chins 200 amp hour 12v Lifepo4 batteries.
AtemPower 40 amp DC to DC charger / MPPT controller, latest version wtih LifePo4 charging profile.
I also need to determine the capacity of the installed inverter, and swap that out for a pure sine wave inverter to protect my laptop and such...
