Robert Shaw Thermostat Danhard Airconditioner
Has anybody replaced the Robert Shaw thermostat that Sportsmobile West installed for the Danhard airconditioner
I’m having problems with the thermostat not staying in the ON position. When I turn it on sometimes I get the code E2. Sometimes when it’s ON it toggles OFF. If I close the thermostat panel or even the drawer below it can cause it to go to the OFF position.
Once I reset the switch to ON and it toggles through (about 2 minutes) it turns the air conditioner ON. Therefore I don’t think it’s anything to do with the air conditioner. I think it’s just a faulty thermostat perhaps the wiring.
This has been an issue since I first bought the van . It would happen occasionally but now more frequently. Just putting pressure on outside of the panel can cause it.
Anyway I was able to buy the exact same thermostat and I’m wondering if anybody has had to replace theirs.
Specifically do you have to turn anything else off. Is it just simply some wires like other thermostats?
Any insight helpful.
