Old 01-20-2015, 02:11 PM   #1
Scangauge II X-Gauge setups
I have programed several X-Gauges on my Scangauge II as listed below. May be of interest to others.
FICM Vehicle Power (Volts) (Should be 12 Volts)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
FICM Main Power (Volts) (Should be 47-48)
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
VGT Duty Cycle (%)
TXD: 07E022096D
RXF: 04620509066D
RXD: 3010
MTH: 00647FFF0000
NAM: VGT
Transmission Fluid Temp
TXD: 07E1221674
RXF: 046205160674
RXD: 3010
MTH: 000100080000
Engine Oil Temp
TXD: 07E0221310
RXF: 046245130610
RXD: 3010
MTH: 00090005F060
2007 Sportsmobile FRB-50 4X4 Diesel, Aluminess front & rear, Espar D4 Airtronic, XL storage, leather, Kenwood GPS, electric Penthouse, Solar panels
2003 GMC Sierra 2500HD 4X4 Duramax Diesel
2006 Jeep Wrangler Rubicon LJ
tyonb is offline   Reply With Quote
Old 01-22-2015, 06:39 PM   #2
Pschitt's Avatar
Re: Scangauge II X-Gauge setups
Great, thanks for sharing.
Old 01-24-2015, 10:40 AM   #3
Here's a few more with recommended levels or settings to watch for. Shamelessly re-posted from this thread. http://www.powerstroke.org/forum/6-0l-e ... -pids.html
KO=KEY ON LI=LOW IDLE HI=HIGH IDLE OR=OPERATING RANGE (High idle for these tests is set at 2500 RPMs, and Engine at operating temps)
FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
?TXD: 07E02209CE
?RXF: 0462450906CE
?RXD: 3010
?MTH: 006401000000
?NAM: FVP
KO=12.0 LI=14.0 HI=14.0 OR=10.5-15.5
?TXD: 07E02209CF
?RXF: 0462450906CF
?RXD: 3010
?MTH: 006401000000
?NAM: FLP
KO=12.0 LI=13.5 HI=13.5 OR=10.5-15.5
FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced.
?TXD: 07E02209D0
?RXF: 0462450906D0
?RXD: 3010
?MTH: 006401000000
?NAM: FMP
KO=47 LI=47.5 HI=47.5 OR=40-52 (yes, that is what it says from Ford)
VGT Duty Cycle (%)
?TXD: 07E022096D
?RXF: 04620509066D
?RXD: 3010
?MTH: 00647FFF0000
?NAM: VGT
KO=0 LI=73 HI=43 OR=0-100 %
Engine Oil Temp
?TXD: 07E0221310
?RXF: 046245130610
?RXD: 3010
?MTH: 00090005F05F (00090005FFD8 alternate MTH found)
?NAM: EOT
Engine hot KO=190 LI=190 HI=190 OR= -40 - 302 *F
Trans. Fluid Temp
?TXD: 07E1221674
?RXF: 046205160674
?RXD: 3010
?MTH: 000100080000
?NAM: TFT
Horsepower
?TXD: 00
?RXF: 400080000000
?RXD: 0000
?MTH: 000A00240000
?NAM: HPR
Inj. Control Press. (ICP / HPOP)
?TXD: 07E0221446
?RXF: 046205140646
?RXD: 3010
?MTH: 003900640000
?NAM: ICP
KO=0 LI=625.5 HI=1400-1450 OR=0-4045
ICP Voltage (Volts)
?TXD: 07E02216AD
?RXF: 0462451606AD
?RXD: 3010
?MTH: 004827100000
?NAM: ICV
KO=0.2 LI=1.0 HI=1.8 OR=.15-4.7 Volts
IPR Duty Cycle
?TXD: 07E0221434
?RXF: 046285140634
?RXD: 3008
?MTH: 0DCA03E8000A
?NAM: IPR %
KO=14.84 LI=24 HI=40.60 OR=0-50 %
Throttle Position 1 (Volts)
?TXD: 07E0220917
?RXF: 046245090617
?RXD: 3010
?MTH: 006404000000
?NAM: TP1
?Note: Voltage of the ETC Throttle Position Sensor number 1
KO=4.0 LI=4.0 HI=3.4 OR=0.7 - 4.2 VOLT Accelerator Pedal Track 1
Throttle Position 2 (Volts)
?TXD: 07E0220918
?RXF: 046245090618
?RXD: 3010
MTH: 0064040000000
?NAM: TP2
?Note: Voltage of the ETC Throttle Position Sensor number 2
KO=1.4 LI=1.4 HI=1.9 OR=1.4 - 4.1 VOLT Accelerator Pedal Track 2
Throttle Position Desired (Degrees)
?TXD: 07E022091A
?RXF: 04624509061A
?RXD: 3010
?MTH: 0064020000000
?NAM: TPD
?Note: ETC Commanded Throttle Angle, in degrees.
Throttle Position Actual (Degrees)
?TXD: 07E022093C
?RXF: 04624509063C
?RXD: 3010
?MTH: 006402000000
?NAM: TPA
?Note: The measured throttle angle from the throttle sensor inputs.
EGR Duty Cycle (Percent)
?TXD: 07E022166E
?RXF: 04620516066E
?RXD: 3010
?MTH: 006440000000
?NAM: EGR
KO=0 LI=0-15 HI=32 OR=0-44 %
EGR Throttle Position Control Signal
?TXD: 07E022096C
?RXF: 04620509066C
?RXD: 3010
?MTH: 00647FFF0000
?NAM: ETP
EGR Valve Position (mm)
?TXD: 07E022096A
?RXF: 04620509066A
?RXD: 3010
?MTH: 000100010000
?NAM: EVP
?Note: EGR Valve Position in hundredths of a millimeter, where 0 mm indicates a closed EGR valve position.
EGR Valve Position Desired (%)
?TXD: 07E02209D2
?RXF: 0462050906D2
?RXD: 3010
?MTH: 00647FFF0000
?NAM: EVD
EGR Valve Position Measured (%)
?TXD: 07E02209FE
?RXF: 0462050906FE
?RXD: 3010
?MTH: 00647FFF0000
?NAM: EVM
Note: MEASURED EGR Valve Position, in %, where a low value indicates a closed EGR valve (0 EGR flow), and a high value indicates an open EGR valve.
KO=0 LI=0 HI=9.72 OR=0 - 14 PERCENT
EGR Valve Position (Volts 0-5)
?TXD: 07E022167E
?RXF: 04620516067E
?RXD: 3010
?MTH: 000133330000
?NAM: EGV
KO=0.8 LI=0.8 -1.0 HI=1.3 OR=0.6 - 3.5 VOLT
Camshaft & Crankshaft Sync (1 = in sync, 0 = not in sync)
?TXD: 07E02209CD
?RXF: 0462050906CD
?RXD: 3000 (3001 alternate)
?MTH: 000100010000
?NAM: SYC
KO=0 LI=1 HI=1 OR 0-1 (NO/YES)
Intake Air Temperature 2 (Fahrenheit)
?TXD: 07E02216A8
?RXF: 0462051606A8
?RXD: 3010
?MTH: 000100010000
?NAM: IA2
Engine HOT KO=113 LI=113 HI=113 OR= -40-250 *F
Barometric Pressure
?TXD: 07E0221127
?RXF: 046285110627
?RXD: 3008
?MTH: 003100500000
?NAM: BMP
Here is another BAR if the above one is not working for you. The one below works for me.
Barometric Pressure (PSI)
TXD: 07E0221442
RXF: 046285140642
RXD: 3010
MTH: 001D00500000
NAM: BAR
KO=96.5 (14) LI=96.5 (14) HI=96.5 (14) OR=50 - 120 (7.3 - 17.4) kPa (PSI) ?
Exhaust Back Pressure
?TXD: 07E0221445
?RXF: 046285140645
?RXD: 3010
?MTH: 001D00500000
?NAM: EBP
KO=103 (15) LI=110 (16) HI=110 (16) OR=55 - 607 (8 -88) kPA (PSI)
Fuel Level
?TXD: 007E02216C1
?RXF: 0462451606C1
?RXD: 3010
?MTH: 000101480000
?NAM: FL
Volume Fuel Desired
?TXD: 07E0221411
?RXF: 046245140611
?RXD: 3010
?MTH: 006400100000
?NAM: VFD
Mass Fuel Desired (Milligrams Per Stroke)
?TXD: 07E0221412
?RXF: 046205140612
?RXD: 3010
?MTH: 000100100000
?NAM: MFD
KO=0 LI=7.5 HI=10.7 OR=0-100
Engine Run Time (Minutes)
?TXD: 07DF011F
?RXF: 0441051F
?RXD: 2810
?MTH: 0001003C0000
?NAM: ERT
Fan Speed Sensor (RPM)
?TXD: 07E022099F
?RXF: 04620509069F
?RXD: 3010
?MTH: 000100040000
?NAM: FSS
KO=0 LI=533 HI=488 OR=0-4000
2011 VW TDI Golf for hwy fun
Bullwinkle
austineats
The Hulk
Hulk
