Originally Posted by jonyjoe101
I use the 3" celdek, its about the thickest that will fit in one of the smaller swampcoolers I build.
Thanks for the pictures and dimensions. From what you say it is difficult to really cool even the smallish van so it is making me put my thinking cap on to improve the efficiency.
I'm going to try and shoot for you double cooler level performance by ducting all air from the roof fan through a fully saturated media. I will have to see how it works out but it seems like I can get 4.5" x 12" x 6" (HxWXD) inside a 6" little extension to the standard vent fans.
I will have to trim the media down from standard dimensions so I will make adjustments as required. This piece of media should fit under a 9" tall cover
So for example Comeco makes a standard size cover that is 7.2" and an XLT that is 10.5" tall respectively. So I will try and stay at 9" or less.
From the picture, you can see about a 9" height required for that vent cover opening and there is just about 6" of room behind the vent assuming I remove that work light above the upper brake light. So the whole evaporative section will go behind this installed vent/fan. I will have to make a custom fiberglass cover due to the contained space limitations.
You cant see it very well but there is a solar panel and a PCV solar water heater in front of the roof vent. You can see the brass fittings for the liquid vent and pressure relief valve.
You can also see a schematic of the setup. I have a water pump and accumulator so I'm using the main potable water supply to feed the evap-cooler through a standard float valve. There are two pumps one for recirculation and the second for a periodic dump of the water to keep things clean. There is also a cutoff valve which helps to save water during maintaance.
At 9" I can just keep it installed during summer months (May to October LOL) or leave it on all the time. I want to make maintenance easy even though this will have a dump feature to reduce hard water deposit build-up.
I'm still working on the actual dimensions. I plan to plastic weld some 1/8" ABS into rectangular shapes for the three sections of the cooler (upper media drizzle tank, media section, and lower reservoir). If I can keep this precise enough then the size should remain pretty compact.
