Originally Posted by Scalf77
Unfortunately this would be part of the spec that says no. You certainly could do the separate controller, not my preferred set up. I would not stick with renogy controllers either, but again that is my preference.
OK, I understand. Thanks.
I had CCV install my solar system at the same time that they did my pop-top, and they did Renogy brand only, so that's what I have. I also had them install my (2) 6-volt AGM batteries, which was the first time they had ever done that, they were originally going to give me a single 100 ah Interstate deep-cycle battery. I was somewhat distressed to discover that the Renogy solar controller manual did not even mention AGM batteries, and I was advised to just use the "gel" setting to avoid the system trying to equalize the batteries, which apparently is a no-no for AGMs other than LifeLine...
If I may ask, what brand(s) of solar controllers are best, in your own view? I've done a lot of research and it isn't clear to me.
\Paul
