Originally Posted by daveb
Originally Posted by cygvan
ive read that some pv panels come with blocking diodes which minimize this effect to some degree but its still wize to avoid shading.
Yes and some panels use light diffusers to minimize the effect. You’ll see both of these in many of the marine panels that have to deal with shadowing from sails and rigging. The Solara panels were designed that way. Like I posted, I’m not sure about each manufacture. I went with Kyrocera because SMB was using them, they carry a warrantee for RV use, and the rack that Aluminess made was designed around that size panel (135w).
actually i used the wrong term, i was referring to a bypass diode. the blocking diode prevents battery discharge at night. i didnt know that manufacturers did anything different for the marine applications. that makes sense on a sailboat for sure.
everyone ive spoken to recommended the kyocera panels without reservation really so i chose that same 135w panel. i changed my mind between that and the 185 panel a few times before i got real lucky and i was given a solar world 245 as a gift.
here is an excerpt from the kyocera installation manual for the kd series panels:
9. BLOCKING DIODES
In systems utilizing a battery, blocking diodes are typically
placed between the battery and PV module output to
prevent battery from discharging at night. KDxxxGX-LPx
series modules are made of polycrystalline cells with high
electrical “back flow” resistance to nighttime battery
discharging. As a result, KDxxxGX-LPx series modules do
not contain a blocking diode when shipped from the factory.
Most PV charge regulators and inverters incorporate
nighttime disconnect feature.
10. BYPASS DIODES
Partial shading of an individual module in a source circuit
string (i.e. two or more modules connected in series) can
cause a reverse voltage across the shaded cells within the
module. Module output current is then forced through the
shaded area by the remaining illuminated cells and other
PV modules in series with the partially shaded module(s).
The current forced through the shaded cells within PV
module (or modules) causes additional module heating and
severe loss of power.
All KDxxxGX-LPx series modules are
supplied with factory installed (non user serviceable)
bypass diodes.
The purpose of bypass diodes is to provide a low-resistance
current path around the shaded cells, thereby minimizing
PV module heating and array current losses.
PV modules employ bypass diodes that have:
? Rated Average Forward Current [IF(AV)] Above
maximum system current at highest PV module
operating temperature.
? Rated Repetitive Peak Reverse Voltage [VRRM] Above
