Old 04-16-2024, 08:01 AM   #11
If you don't see any heat damage to sheathing. I would doubt it could have ever generated enough heat to cause damage. Also, if it did it would have shown up more as an open circuit, and not blowing the fuse.
Old 04-16-2024, 01:43 PM   #12
BrianW's Avatar
Do the fans turn when the system is on? Or, can you even spin by hand?
Old 04-16-2024, 02:17 PM   #13
MrHenrietta's Avatar
Fan does not turn on when system is on but the fan spins by hand no problem. Worked fine last time I used it..
MrHenrietta is offline   Reply With Quote
Old 05-13-2024, 03:50 PM   #14
Just updating the thread with the solution. Ended up being the rear condenser fan as others said above. I purchased a new fan from Amazon for about $30 and easily retrofitted it to the plastic condenser box. Good as new. Thanks all.
2003 7.3 UJOINT 4x4 SMB
Old 05-14-2024, 07:50 AM   #15
Do you remember which fan from AMZN did the trick/fit ? Thanks -
Old 05-14-2024, 08:21 AM   #16
This is the fan I used. Itís not a direct fit but I made it work. I cut the old fan out using an oscillating saw because there was no way the whole condenser box was coming out without removing my drive shaft.
https://a.co/d/eTaiA5w
