Old 10-11-2011, 09:49 PM   #1
Starter battery replacement
After almost 7 years I'm going to be proactive and replace the starter batteries. All the vehicles I've owned the batteries seem to be programmed to fail at 5 years, so I guess I've been lucky. My concern is having to reprogram my radio / CD player. When the batteries are disconnected all is lost, and I have to start from scratch. The radio / CD player is so freaking complicated, that it seems to take the better part of a day to get it straight again.
If I turn the "radio" switch on, will the house battery keep current to the radio while I disconnect the starter batteries? Or, is there a way to disconnect one of the two starter batteries and just replace one at a time to keep current to the radio?
I'm just a real techo-phobe when it comes to fancy electronics and don't want to have to reprogram the damn radio.
thanks..
Tom
2005 SMB RB 50 4X4 w/ a 6.0 PSD
flyfisher is offline   Reply With Quote
Old 10-12-2011, 03:48 AM   #2
Pntyrmvr's Avatar
Re: Starter battery replacement
Hi Tom;
Go find a lighter socket adapter that accepts a 9 volt battery. You plug it in to the lighter socket with the 9 volt connected and it provides enough power to keep the radio memory going while you swap out starting batteries.
No idea where to buy one, but I have seen them at dealership service departments.
Start with Google and go from there.
Regards,
Gavin
Old 10-12-2011, 08:36 AM   #3
Great idea, thanks Gavin.
Old 10-12-2011, 09:58 PM   #4
geoffff's Avatar
A quick Google search turns up ...
"12V Automotive Settings Keeper w/9V Battery - Keep Your Personal Settings When Replacing Your Car Battery!"
http://www.geeks.com/details.asp?invtid=GK504&cat=GDT
-- Geoff
2004 Ford, SMB 4x4, RB-50
Old 10-13-2011, 05:50 AM   #5
Pntyrmvr's Avatar
Hi;
Geoff that is the piece I saw. For $8 it should help prevent a lot of grief while swapping out a battery or two.
Regards,
Gavin
