Originally Posted by Twoxentrix
Another option you may consider is Carbon Foam batteries; sort of “middle ground” between Lithium and AGM (draws down 80% like Lithium, but has 3X’s the Lifecycles than AGM). Used a lot in the Marine industry.
https://www.totalbattery.com/product/firefly-energy/
I've seen several references to these and have been intrigued. I checked out the link you gave, plus the specs on the Firefly 12VG31 (
https://webstore.totalbattery.com/Fi...1-p/12vg31.htm) and have the following comments:
1. One advantage LiFePO4 batteries have is weight. From what I can see, the carbon foam battery weight is comparable to, or at least not dramatically less than AGMs (and more than LiFePO4s).
2. They also seem to be in the same price range as premium LiFePO4 batteries like Battle Borns.
3. I can't find an amp hours spec, just 720 CCA, which isn't important for house batteries.
4. For what it's worth, there are zero reviews.
Based on the above, I'd still go for the LiFePO4s.
