Originally Posted by Twoxentrix
Did you pop the top and look underneath to see what (if anything) is holding it in place? It's possible the unit is wedged in the hole Sportsmobile cut for the light fixture (they weren't exact in everything they did).
When you say pop the top do you mean the lens or the housing? Either way nothing has popped yet for me. I just order a replacement housing because something is going to break and I’m about to leave on a extended trip.
I took both screws out and I have pried all around the lens and the housing. The housing is a little looser but not by much. Just wanted to make sure I’m not missing something like there are bolts on the inside of the van holding the horsing I place.
Edit:now that I think about the bulb access might be inside the van behind carpet.
