Originally Posted by Scalf77
This is my thought of a DIY Ravelco type system. We substitute the CPC connector with RFID controller. You get in the van and the RFID key fob allows access.-greg
One thought, a quick glance at the unit makes me think the fob needs to be in close proximity at all times to activate the relay, if it were moved too far away, it could cause the motor to shut off, so some method should be devised to make sure the fob can't move while driving. If the fob was on the ignition key chain and the receiver nearby that could solve the issue. Meanwhile, I just ordered one to play with, the possibilitys are endless, thanks..............
