Have the 12volt isolated version & it is up and running. I have the lithium battery default setting. On my Magnum inverter I have it set for AGM2. I have two BattleBorn 100AH batteries. When plugged into shore power the Magnum remote unit shows absorb charge. Disconnecting shore power and starting the engine the Virton unit shows Bulk Charge. Should they agree?
The Magnum ME-RC Remote Control should allow you to select LFP battery type through the menu. Older software versions require you to use cc/cv option when using lithium. This thread may be of some help to you, as it was for me. https://www.sportsmobileforum.com/fo...ion-26012.html
This is an a copy of the Magnum settings for a Sprinter with lithium batteries. http://rick.samcos.com/downloads/Spr...00Settings.jpg
You can always call Sensata Technologies (651-653-7000). Their technicians will walk you through the process of selecting the proper parameters for your battery system and components. Hope this is helpful.
Thanks for the help on the batteries. I am working through it all. And we are trying to get Rocinante on the road after upgrading to lithium and replacing the 10 gallon water tank with a 22 gallon tank. But as luck would have it the water pump died and I decided to move the pump to a position under the sink. Too crowded in the area under the couch.
