RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 08-04-2020, 09:21 PM   #1
Mikerson's Avatar
What do you call this battery box and where can I get another?
I’m interested in adding a second battery to my van. I’d like to reproduce the existing setup from the passenger rear corner on the drivers’s side rear. The existing battery is a group 27 in a fiberglass box. The box appears to have flanges that support it after dropping in the hole cut in the van floor. I kind of like the battery access from the inside for security and protecting the battery from the road salt.
I’ve searched all over google for fiberglass boxes and the only similar boxes I can find are used for European race cars. I found UK and German sites with something similar, but as you can imagine the cost+shipping is too much. Where the heck did SMB get these originally? Any idea where I can get one now? Is there a modern/better way to box a second battery? Thanks in advance.
41FEE530-ECAE-4AA6-8EBB-5ACBCA80888C.jpg   9530F070-ACA8-4DC2-93FC-A61A1DF79003.jpg   BE30681A-ABF4-4A0B-BFB2-35F57B34BAF9.jpg   029ABF66-15C3-429F-9403-810E6B5440E4.jpg   C1E6375B-CC12-4433-9280-5AAA07B86110.jpg
Mikerson is offline   Reply With Quote
Old 08-04-2020, 09:46 PM   #2
Steve C's Avatar
I've never seen a set-up like that before. I agree that it's a handy way of carrying the batteries with better access and protection from the elements. Seems that a local welding shop could replicate that in either steel or aluminum for around $600?
2001 Sportsmobile RB50 7.3
West Central Mountains, Idaho
Steve C is offline   Reply With Quote
Old 08-04-2020, 11:31 PM   #3
That looks totally custom to me as well.
Not sure $600 custom. But will probably be at least a few hundred for sure.
Not a bad way to mount them. Will need a few more dollars in wiring it up.
Maybe check with a stereo shop. They could probably build a glass box like that.
Old 08-05-2020, 06:54 AM   #4
shenrie's Avatar
Google flush mount or recessed battery box. There’s a few different companies out there that make them. Here’s the first one that came up when I searched. No idea if any of them make ones big enough for van needs.
https://jfmco.com/product/battery-box-flush-mount
Fabbing one of those up shouldn’t be $600 unless you have a shop in a resort town do it. Aluminum would definitely be more than steel, but I’d hope you could get one made for under $300. Then again, anything attached to #vanlife will be 3 times more than it should be, so steve may be right on the mark with his guess.
Old 08-05-2020, 08:24 AM   #5
Mikerson's Avatar
Thanks for the responses everybody. Using the term “flush mount box” definitely opens up a few more options. The original is fiberglass, which seems to be holding up well and is lightweight and corrosion proof. Quick search didn’t show any made of FG. I guess 20 years of marine/automotive progress has eliminated this product from the market. I had no idea this was such a rare setup on top of it. Is it possible that SMB fabricated this custom for the original owner?
Old 08-05-2020, 10:43 AM   #6
What about contacting a marine shop that works with fiberglass?
Searching the internet for fiberglass battery box doesn't result in much...and here are some links that might help.
It shouldn't be too difficult for a shop that already fabricates fiberglass boxes to create one with a flange for recessing.
Custom Fiberglass & Repair Examples
Battery Boxes for Equipment & Industrial Use | http://batterybox.com
https://www.ironhorseauction.info/au...-and-lid-50232
https://www.cruisersforum.com/forums...ox-108763.html
https://www.cheaprvliving.com/forums...box?pid=271871
https://www.fishonfabrications.com/c...brication.html
Chris
2006 E350 4x4 SMB: 6.0L-5R110-Atlas-D60-D60-yada-yada-yada
Old 08-05-2020, 11:21 AM   #7
Not sure if it is totally custom, just maybe an older SMB setup. I had a 1995 Dodge SMB with a double battery setup using the fiberglass flush mount underfloor boxes.
Old 08-05-2020, 01:56 PM   #8
Yep, that is an older SMB setup. Many vans from mid 90's back had them done that way.
They might still sell you the box, who knows. It's worth a call. Remember all SMB locations are different. You'll have to call each one. My guess would be Nancy at the Indiana SMB location would be your best help.
Currently vanless. Weird.
Old 08-05-2020, 07:10 PM   #9
I have the exact same thing in my 2001 Ford E350 SMB, debating on lithium or AGM and that will determine if I make it bigger to fit a couple batteries or not.
Michisurfer is offline   Reply With Quote
Old 02-08-2021, 05:18 PM   #10
Hello, I'm checking to see if you found an original fiberglass box from SMB or went another direction. I had two of these installed in my 95 E 250. I now have only one.
Squirrel_murphy is offline   Reply With Quote
EB Van
ebflow
Woodstock
woodstock
