Factory Axillary battery not to be confused with an SMB installation, which is where the "house battery" radio switch comes into play.
Originally Posted by joey2cool
I've seen some chatter on the forum about SMB's house battery circuitry connection via a relay to the radio, but I couldn't understand how it can be a liability to the starter battery if the radio is turned off and the relay is not switched back to the SMB house system.
Depends on how they wired the relay, or if it even is a relay. I haven't been in there to see how it is wire, but the reverse light override switch is a rather interesting solution so I wouldn't be surprised at most anything. Also there is a light involved after a certain year. Best post this question as a separate thread.
I'm having a battery isolation switch installed to avoid the hassel of removing propane and CO detector fuses in order to prevent SMB house battery drain.
Why not just install a 12v switch inline to disable the fuses? That's one of my grand plans that I haven't gotten around to. Reminds me I need to check my voltage since the van is sitting...
