Originally Posted by plarkin
Klompen - That is the fuse I am looking for....it was not installed by SMB when they installed the Solar system on my camper. Hope you didn't fry your controller!
Fortunately, the controller is fine (thanks to the fuse).
FWIW, the problem that I contacted Zamp about was understanding why the controller was showing a cycling of amps when I had both panels connected. It would show 6+ amps as expected, then count down to zero, then do it all over again. It also showed very rapid flashing of the bar graph. I asked Zamp why the controller did this and what this meant.
After replacing the fuse, I figured out that this behavior was because my battery was close to full charge. Once it achieved full charge, the behavior stopped. I was appalled that Zamp could not explain how their own controller operated (and it wasn't in the documentation).
