Old 06-10-2021, 05:48 PM   #1
Windshield wiper fluid sprayer thingy...
Am I alone in that the Ford E350 factory windshield wiper fluid sprayer engages only after the wiper blades make a dry sweep first, resulting in fresh bug guts being smeared across the glass, rendering the washer fluid ineffective?
Any suggestions on how to remedy this would be greatly appreciated!!!
PS - My wiper fluid pump is brand new.
It's not how far you go, it's how go you far...
Dual Carbs is offline   Reply With Quote
Old 06-10-2021, 06:57 PM   #2
Oogs's Avatar
You are not alone. We were just talking about this on our last trip and commenting how this doesn't happen our our Toyota.
The other thing is the wiper chatter. Our last van did it as well. Love the SMB but come Ford?!?!
Oogs is offline   Reply With Quote
Old 06-10-2021, 06:59 PM   #3
Twoxentrix's Avatar
This seems to have been a low cost solution (just have to make sure its raining first):
https://youtu.be/JnDwajYShgI
TwoXentrix
"AWOL"
Old 06-11-2021, 12:24 AM   #4
arctictraveller's Avatar
I worry about scratching the windshield so I just poor water on the windshield from my water bottle first.
Old 06-11-2021, 08:40 AM   #5
Most E-series don’t do this. I’d suspect a plugged or worn out check-valve. I don’t know where it is, but you can just splice in a new one anywhere.
As far as wiper chatter…. Put on new blades. All blades do this when they get brittle. It’s not a design problem. All wiper blades among all brands are made by just a handful of MFGs. They don’t make their own.
Old 06-18-2021, 07:17 AM   #6
My 07 sprays for a solid 2-5 seconds prior to the wipers engaging.. I think carringb nailed it.
My issue is aiming the nozzles... They spray nicely on the top 1/4 of the windshield and the front of my hi-top when at a stop.... works a little better going down the road! I've had no luck lowering the spray though.
sierraoneill is offline   Reply With Quote
Old 06-18-2021, 02:41 PM   #7
Interesting, my wipers start immediately and it takes a wipe or two prior to any fluid spraying. Mine also hits just the top of the windshield so I pulse it on and off to wet more of the lower part.
Tags
delay, fluid, spray, windshield
Rosy
Isever
1997 Ford E350
Fool120
