Old 02-11-2021, 07:42 PM   #1
Can you add penthouse motor to manual pop top?
Just wondering if you can add a motor to a SMB penthouse top to a SMB top that's currently a manual pop up?
leblanc is offline   Reply With Quote
Old 02-11-2021, 08:36 PM   #2
I'm almost certain that Sportsmobile (the company) used to retrofit them. Someone here will remember.....or know.
I think it would involve some fabrication though, which could be huge or a walk in the park depending on your skill level.
Old 02-11-2021, 09:00 PM   #3
I did send them a message, just waiting for a response. Figured someone here would know for sure.
Fabrication won’t be an issue. I can make anything work, just wondering if there’s a kit or if maybe it’s an all DIY sort of thing.
I’d love to see what motor is used and what the linkages look like.
Old 02-12-2021, 01:28 AM   #4
Orv
I think you can find pictures on the forum if you poke around some. As I recall they're using two linear actuators, pushing horizontally on the bottom end of the scissor lift tubes. One flaw in this system seems to be that if a hook catches or anything else restrains the top, the tubing bends pretty easily.
That's just my recollection though -- I have a manual top.
I've also seen non-SMB systems that used an airbag at each corner to do the lifting, which is an interesting idea.
N8SRE
Old 02-12-2021, 05:47 AM   #5
Twoxentrix's Avatar
Don’t know if they still carry it, but I believe at one time Aluminess offered an air lift to help raise manual tops (believe you needed to hook an air compressor to it). If I recall correctly it was a single pole you positioned between the floor and middle of your top.
Old 02-12-2021, 07:12 AM   #6
I had SMB Texas retrofit my top with lift motors. Plan on it taking 2 days of their time - if they get it done faster great, but if they have problems it will take 2 days. Get a hotel room, get your stuff out of the van, then drop it off.
And of course, be prepared to wait for a time slot to open - ALL RV places are tremendously busy right now.
Wowbagger is offline   Reply With Quote
Old 02-12-2021, 07:14 AM   #7
SMB Penthouse Top Motor ?
Greetings -- I recently checked into the price of a SMB Penthouse top motor - quoted at $ 300 bucks at SMB North. Anybody know where the motor is actually mounted and where to gain access ? I don't need one as mine is working - but it is 2002 vintage. Just want to be ready "if."
Old 02-12-2021, 09:09 AM   #8
I got a response from Sportsmobile: "If it’s a Sprinter it might be possible, if it is an E-Series then no its not."
It is an E-series van by the way.
Old 02-12-2021, 09:09 AM   #9
That would be great if someone could post some motor photos to include mount location and linkages. If it's not too much to ask.
Old 02-12-2021, 09:34 AM   #10
There are a bunch of SMB top pictures in my album without all of the covers in place.
https://www.sportsmobileforum.com/fo...rks-page3.html
