Originally Posted by daveb
Sucks when you can't use your PH because you've strained your back
I second that....although I also tightened the spring tension and put in a bigger block on the preload, that helps, along with unhooking the bed when putting it up. The added weight of the solar panel doesn't help, although turning the fan on high with everything shut trick helps, on the flip side, if you don't have the engine running and fan on and have everything shut, it creates a suction when you try to raise the roof, done that too many times, opening a window or door is a must. We have managed without, that being said, we would add it to a new build.....
