Old 12-30-2020, 06:46 AM   #1
Plastic wall panel removal - E350
I'm hoping someone can walk me through removing the plastic wall panels in my E350 wheelchair van. I need to remove them to install some seat belt assemblies that had been removed and don't want to damage them.
Bob
2002 Itasca 35U Motorhome
BCam is offline   Reply With Quote
Old 12-31-2020, 10:20 AM   #2
I just did this four times over the weekend. Start at the rear doors, driver side and pull the weather stripping back—you’ll see three or four black plastic plugs that need to be pulled out. This is the hardest part. Once those are out, yank on the upper trim, toward the inside of the van, til it pops out. They are press-fit and you’ll see the mounts once you start pulling them. Look for screws and remove screws, then pull. Pretty much the same on both sides of the van. I was surprised none of my mounts broke but the older the plastics, the more chance you have of something breaking. No big deal.
Chico is offline   Reply With Quote
Old 12-31-2020, 10:24 AM   #3
Thanks, I figured it would be something like that but it's so easy to break something.
Four times in one weekend? There has to be a story behind that.
Bob
