Old 08-10-2022, 03:45 PM   #1
Awning bracket/door
Did you have to adjust your passenger door hinge in order to close the door after installing the bracket for Fiamma awning?
Glippie is offline   Reply With Quote
Old 08-10-2022, 05:19 PM   #2
Which style bracket are you using? On what type vehicle?
Old 08-10-2022, 05:37 PM   #3
At Field Van in Reno. Attaches to the rain gutter.
Old 08-10-2022, 09:53 PM   #4
1der's Avatar
What make of van? Who installed the brackets? Field van attaches to the rain gutter? No bolts into the body?
If you have just over 1/8th inch or more gap between the top of the door and the bottom of the gutter you should not have to adjust your door. If all the body lines line up along the side of the van then any adjusting will create misalignments. If they are already misaligned then adjusting the door can serve two purposes.
You may have to adjust the bracket by redoing a bend or two. This should NOT be done on the van. Remove the bracket and use a vice to make the fine adjustment.
Some pictures might help.
Old 08-11-2022, 09:44 AM   #5
I didn't have it installed after I was told I would have to adjust the door. It's a '97 E250. Wanted to check with all of you and my Ford guy before I gave a thumbs up.
Old 08-11-2022, 01:46 PM   #6
I installed the gutter type bracket. You might have to bend it to get it to fit properly, but you don't have to adjust the door.
