Did a mockup today to check the fit. It's about 1/4 inch too wide at the bottoms of the mounts, which will be easy to fix. This is using the KSuspension rain gutter mounts and the basket from a Titan Ramps "Hitch Mounted Steel Cargo Carrier Basket 500 LB Capacity." I picked that model because its dimensions were a good fit to the van's roof. I believe this is the same hitch carrier that Jegs sells, just with different branding.
Sorry about the picture quality, I was rapidly running out of light. I also didn't bother to install the clamps on the gutter mounts because I was just checking the dimensions.
After some minor tweaks to improve the fit, the next step will be to take it apart and paint it. I have to paint the mounts anyway (they come as bare steel), and the paint on the Titan carrier is sub-backyard rattlecan quality so I'm going to do it too. I'll probably shoot truck bed liner on the expanded mesh in the bottom -- I used it in the tire channels of my motorcycle trailer and it's held up very well.
N8SRE
