Old 03-16-2020, 09:34 AM   #1
jredone's Avatar
Light bar mounts Aluminess front bumper
Hey guys/girls
Front bumper for my rig should be here in the next few weeks. Im looking to mount my rigid light bar on the brush guard tubing. Reached out to Aluminess on actual tubing size and they are 1.5 ID and just shy of 2 OD.
Not sure if I should go with 1.5 1.75 or 2. Are there adjustable mounts say 1.5-2?
Whats everyone using?
jredone is offline   Reply With Quote
Old 03-16-2020, 03:58 PM   #2
DesertSMB's Avatar
I made the same addition to my van a couple of years ago. I went with the 2 inch clamps. I had to use shim material to get a tight fit. I used some aluminum roof flashing material I had around which I'd gotten a number of years ago for another project. I don't believe that 1-3/4" clamps would work.
Chris/Bev
2012 E350 EB50 V10 Cruiser Top
Sportsmobile 4WD Conversion
DesertSMB is offline   Reply With Quote
Old 03-16-2020, 04:42 PM   #3
jredone's Avatar
Think a 1.875” would work or should I just go 2” and shim?
Old 03-16-2020, 04:43 PM   #4
Twoxentrix's Avatar
I purchased 2" clamps for a different reason than a light bar, cut some strips out of thin rubber matting (something that would not absorb moisture, and would help guard against marring the powdercoat if I removed them) - wound the strips around the tubing (think it ended out being wrapped twice) then tightened the clamps. No issues.
Old 03-16-2020, 04:48 PM   #5
jredone's Avatar
Thats the route I was thinking. Any specific brand you guys using? Rigid pricing is a bit crazy for a simple clamp.
Old 03-16-2020, 04:56 PM   #6
Twoxentrix's Avatar
These are what I used, but again my application was not for lighting.
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
