Hi KI6BEN,
Rhino Rack folding mount here as well. It will fit in a crossbar if the bar has a slot. A square/round light bar mount can be used with the RR folding mount; see links below to product examples and my install, perhaps of help.
I used an NMO mount instead of a bolt type, so I had to modify the RR mount. I added those pics to my album below in case you want to see what I did; think saws-all.
I'm also running a COMPACTenna that has seemed to work well over the past month; still testing. Last pic in the album and link below. A relatively "new" antenna (evidently old redesign) "odd" design; you can look up the patent at the USP&TO site to see how it works.
Key benefit, as the name implies, is its compact! Only 7.5 inches tall.
Again, hope the info helps.
Best,
Em -
KG6HDV
SMB HAM Install
https://photos.app.goo.gl/X5Vd8T1BZfzBY9kR8
FOLDING AERIAL BRACKET
https://bit.ly/3sEhlCb
UNIVERSAL LED LIGHT ADJUSTABLE MOUNTING CLAMPS
https://bit.ly/3HzMzQV
COMPACTenna
https://bit.ly/3gq2Bkj
