I have a 5 gallon tank, being able to start the compressors before you stop and having it ready to go helps a lot.
Initially I used a single Viair 400C, and was pretty unhappy with it. Adding a Wolo 860-C purely on spec helped a lot. It moves way more air than the Viair, is cheaper and appears to be roughly the same construction. Perhaps I just got lucky and ended up with a good one. It does blow the fuse on occasion, I don't quite recall the size, but IIRC the next size up was scary enough that I just live with that behavior.
If I did this over, I'd just get two of the Wolo compressors.
I also learned that getting my tires, that I usually run at 70 PSI, to 60 PSI or so will get me to the next gas station with more serious air easily enough.
