Old 09-25-2018, 01:50 AM   #21
Derek's Avatar
Does anyone know of decent electric heaters? I have an overwhelming fear of the propane ones and would rather spend the extra money on a battery bank that can handle electric heat than risk my life and still be cold due to paranoia with propane.
Derek is offline   Reply With Quote
Old 09-25-2018, 11:04 AM   #22
Flux's Avatar
Why not go with an espar?? Diesel and gas options that pull directly from the tank. They are tiny. Many with gas engines buy the diesel and hook up a small diesel tank to it, some even mount them inside the van. Diesel is pretty safe.
I have a gas espar heater (B4) and it absolutely cranks. Have had the van down to 5°F with the pop top up.
They make a smaller version called the B1LC, which is comparable to the D2 diesel version. If you have a hard top van that would be plenty.
Plenty of folks sell them in the US. I ordered my B4 from these guys and it came no issue and they are good about returning emails with questions:
https://www.heatso.com/eberspacher-air-heaters/
These guys are great too:
https://esparparts.com/
<br>
Old 09-26-2018, 11:37 AM   #23
Blowby's Avatar
Originally Posted by wish41 View Post
Question on that portable Planar unit: if I were to have a hole in the floor of the van to put the exhaust piping, would it be safe to have the rest of the unit inside?
This may answer you question!
Blowby is offline   Reply With Quote
Old 09-26-2018, 11:40 AM   #24
Blowby's Avatar
Originally Posted by gnty View Post
I just pickup one of these guys for winter tent camping on our stocking order. You could use the same thing, have it outside and maybe have a port in the floor or wall of your van that your hook into? Just a thought, its pretty slick. Then you can use it for other occasions as well. Just a thought.
https://planarheaters.com/product/po...-planar-2d-12/
gnty have you had a chance yet to try out your heater?
Was also interested to know whether these planars need a high altitude kit.
Thanks
Roger
Old 02-24-2019, 03:47 PM   #25
ConnieKat's Avatar
Hey guys,
I too am looking for a small, portable electric heater!
Previous owner had everything assoc. with propane removed, including hoses, tanks, stove, etc. I have bought a small electric ( solar) generator to help support electric items if not plugged in. I likely need a third house batt to add to that, since everything needs to be electic or extremely portable gas or propane ( stove). Suggestions and/ or thoughts on this would be very much appreciated!
Thanks,
ConnieKat
ConnieKat is offline   Reply With Quote
Old 02-24-2019, 06:19 PM   #26
Originally Posted by ConnieKat View Post
Hey guys,
Thanks,
ConnieKat
Here's why it's tough to do.....
Let's say a typical small portable electric heater is 1200-1500 watts....
Using 1200W for easy math it would draw 10 amps of current at 120V or 100 amps at 12V. 120V x 10A=1200W 12V x 100A =1200W
Assuming that you have a pair of 4D house batteries (that's a nice setup with a couple of large batteries) ....and they are rated at 200 amp-hours (AH) each.....so 400 AH total.
Lead acid batteries don't like to be discharged past about 50% state of charge (SOC) .......so if you draw your pair of 4D batteries down 50% you've consumed half of your 400 AH, so 200 AH.
So the heater consumes 100 amps at 12V when it's running, and you've got 200AH of energy.
200 amp-hrs/100 amps = 2 hours
..so running the small 1200W electric heater will drain a fairly large battery bank in 2 hours..not very practical.
It's actually a bit worse than this when you add the inefficiencies of the inverter.......
Old 02-24-2019, 07:10 PM   #27
Most people get the little buddy portable propane heater. I have one and it’s awesome. Heats the van right up in about 10 min. Has an auto shut off if it detects CO. Runs off 1 pound propane bottles that slot right in, so there’s nothing extra. You can get them on amazon.
Old 02-25-2019, 02:08 AM   #28
ConnieKat's Avatar
AKA......yikes!!!!
Old 02-25-2019, 02:11 AM   #29
ConnieKat's Avatar
Thanks for the suggestion. Will absolutely take a look.
It’s been very cold up here lately, with a lot of snow. Not that I’m complaining, we do need the moisture.
Old 02-25-2019, 10:00 AM   #30
ConnieKat: Does your van have a CO detector?
