Originally Posted by ConnieKat
Hmmm? On a trip east through northern NM not long ago I got hit with extremely high wind gusts! Result was ripping the door out of my hand ( and nearly wrecked my arm as well. The result was a driver’s door that was blown too far forward and bent the hinges pretty badly. Do you guys think this gadget would hold a door well enough to prevent a replay of this incident? It was insanely expensive to get fixed.
Or maybe some other method?
Thanks,
ConnieKat
That happened to my dad's van, too. Also bent the front fender where the door hit. My friend also had it happen on his E-van. The side and rear doors have door limiters that keep the door from opening too much. (As an aside, if you weren't aware, these door limiters can be overridden to allow the doors to swing fully open if needed.) The front doors don't seem to have them as the hinges are supposed to limit the forward action (but that obviously doesn’t always work).
As Bassy7 noted, that device you asked about is usually put on the rear doors of ambulances, wheelchair vans, etc., to hold the door securely open while loading.
