Originally Posted by Jakob
And why won't rsc work?
You need the crossover steering, so that the rotation of the steering wheel sensor matches what the computer expects to see from yaw-sensor.
Considering your scenario, you should really consider the ExoVans conversion kit. It utilizes the newer axles (2011+) which which are much better axles (brakes, bearings, etc) is a better suspension setup IMO (I prefer coil springs) and will already work with RSC.
It'll probably end up costing less too. Even though you'd need a newer more expensive axle, you can buy a used axle that isn't modified, and less extra parts overall.
