Old 09-10-2016, 08:12 AM   #21
Originally Posted by occasionaldirt View Post
Front:
Bilstein #24-186643
Rear:
Bilstein #24-221948
1993-1999 Suburban springs; I ordered General Spring 1999 3/4 ton Suburban springs, with Energy Suspension spring bumpstops 9-9132G (to replace cheap plastic slides that come on the bottom leaf).
Where did you actually buy them Leaf Packs from? I saw a couple places , but just want to make sure I purchase the right ones .
Mcarpenito89 is offline   Reply With Quote
Old 06-22-2017, 06:22 PM   #22
shocks
So do you know how much longer these shocks are than stock? I have a similar build going on...Lift is done but I want to upgrade the shocks because the front end is resting high in the travel stroke. Not sure if my shocks are restricting the swingarms from dropping.
Front:
Bilstein #24-186643
Rear:
Bilstein #24-221948
mazuko is offline   Reply With Quote
Old 06-26-2017, 02:07 PM   #23
accrete's Avatar
i don't know if it is of any assistance in the builds (mazuko ?) but the part number that i was sent on our BOR 2" lift are: Bilstein #24-020435 for the rear shock replacement.
Thom
Greetings from the Sunny Southwest, USA
2017 RAM Promaster Conversion. SOLD: 2010 Chevy Express AWD
Van Build Thread @ SMBForums
accrete is offline   Reply With Quote
Old 06-26-2017, 02:21 PM   #24
shocks
Thaks for the tip. i found those same part numbers from a few other sources as well.
I did some research and decided to go with the Skyjacker 7000 series....I am planning on another upgrade in suspension down the line so I am going the cheap route this time I
