Old 05-19-2019, 11:50 AM   #101
2012 E-350 EB V10, 4x4, CCV Top
Electrical Wiring
With the cabinets in I was able to finalize the electrical layout. It seems like I have way too much wire in a little campervan, so maybe I went a little overboard, but I figured it was easier to add wires now, than to have to do it later.
The wiring is mostly marine grade duplex wires, mostly 12 and 14 ga.
I also added LED strip lights to the underside of the bed. This give us plenty of light when the bed is raised up. I used a dimmer switch that allows us to adjust the brightness.
Wall Covering
I previously cut some 3/16 plywood walls, and now it was time to cover the walls with foam and fabric.
I set up a table outside, but was a little worried due the forecasted rain, but we finished just as the rain started. I used a siphon gun to spray the contact adhesive to the plywood and foam. Once the foam was glued to the plywood, I used a razor blade to trim the foam flush to the edge of the plywood.
I then sprayed the foam and back of the fabric and glued them together. The fabric was trimmed with about 2-3 inches of overlap.
I cut the corners and used more adhesive on the edge of the fabric and wrapped the fabric around to the backside of the plywood.
It was pretty easy and the corners all look good
cthayn is offline   Reply With Quote
Old 05-19-2019, 12:10 PM   #102
Final insulation and wall panel installation
I used staples and spray adhesive to hold the Thinsulate in place until the wall panels were installed
Old 05-19-2019, 12:20 PM   #103
marret's Avatar
Really coming together nicely.
Chris
Old 05-19-2019, 01:34 PM   #104
Twoxentrix's Avatar
Agree, Very well done.
Old 05-19-2019, 01:48 PM   #105
Man people like you make anything I do look like utter crap. Great work!
Old 05-19-2019, 08:45 PM   #106
I couldn't have said it better. Seriously nice work there.
Old 05-20-2019, 04:38 PM   #107
nice job on the wall panels...ill be doing them soon...im kind of dreading them
axcxnj is offline   Reply With Quote
Old 05-20-2019, 05:03 PM   #108
shadetreevanman's Avatar
Wow. I've read bits and pieces of your thread before, but somehow have missed a bunch of it. Today I read it through from the beginning and you have an incredible project going. Nice work all around. Makes me want to start over on mine and make a few different choices. I may be stealing that formed ABS idea.
Tim Potts
Old 05-20-2019, 06:45 PM   #109
Thanks for the compliments. I’m not too consistent in updating this thread, but I will try to do better.
Old 05-21-2019, 10:41 AM   #110
Nice router work to make the cabinet dados.....keep it coming!
