No there are 20amp GFI's out there.
My rear (aka: bathroom) van wiring:
Lwr switch and timer is for house battery charger when on shore power
Two duplex outlets at sink. Right one is a 20 amp GFI (note the shape of the female connections under "SHORE" label).
Shore power comes into this outlet first and then all others are down stream of it and are GFI protected. I originally located the plug as shown. Never, NEVER had it trip....so wanting 4 outlets I could use all the time I moved the 20 amp GFI under the sink and had 4 outlets at the side of the sink that could run on shore or inverter power. MISTAKE.
Started tripping the GFI a lot and always had to crawl under sink to reset. So, I moved it back to were it was very easy to get at.
