Old 12-13-2020, 10:01 AM   #71
Pntyrmvr's Avatar
Check under the hood for the sticker showing what the van was built with. If legible you may see weight rating and gear ratio of axle.
Most times that sticker is missing or faded. If faded take a photo of it with and without flash on. Sometimes the letters will show up on camera, but not to the naked eye.
Old 12-13-2020, 11:53 AM   #72
Pntyrmvr's Avatar
Here's photos of the gear ratio tag, and the BOM in 2 different zoom levels.
Note how faint the BOM stamping is. Expect to do some sanding or use a powered wire wheel. Still haven't found the BOM on the front axle.Click image for larger version
ID:	37419Click image for larger version
ID:	37420Click image for larger version
Old 12-13-2020, 07:36 PM   #73
campism's Avatar
Originally Posted by Pntyrmvr View Post
Suggestions:
Find the axle ratio tag on your rear axle housing. Usually bolted to the differential cover. If not find the BOM stamped into the passenger side axle tube. Usually faces rearward about halfway from differential cover to the spring pad. Can be very faint. Use google to lookup Dana Spicer BOM decoding.
Get good at using car-part.com
I punched in zip 23220 and 1992 Dodge 350 van and got this:
Attachment 37418
I'll give that a look. I have the information from the axle tag but could not find the BOM on the axle housing.
Got a referral for a rebuild kit vendor and prices for those parts with gears seem to equal prices for used axles. I'll have to decide on that eventually.
Bought three swivel seats and a door-mount spare carrier, pieces I've been wanting. Did not expect to find three matching seats.
The gone-but-not-forgotten project.
campism is offline   Reply With Quote
Old 12-15-2020, 05:55 AM   #74
Pntyrmvr's Avatar
One note on replacement rear gear sets.
The cheaper the gears the noisier they will be even when properly installed.
Some people hear them and are okay with it, others wish they'd bought higher quality gears initially.
Your call.
Old 12-15-2020, 06:41 AM   #75
campism's Avatar
Yeah, I noticed quite a spread from cheap to not-cheap. Thanks for that tip.
Bought a third doghouse for the van with the second accessory console. The first was found at my old neighborhood junkyard and came out of a van that had been spraybombed metallic blue inside and out. I figured I could clean it up when the time came but found a better one at the new place.
The original.
The blue one.
The best one.
I also started cleaning up the swivels.
Old 12-15-2020, 10:32 AM   #76
Pntyrmvr's Avatar
Wow that doghouse console sure is blue.
If you use those swivels up front be aware they are not symmetric about the center of the base plate meaning there is a left and a right version needed to clear all the obstructions as you spin it.
They always need a bit of monkeying around pre spin to get the seat in the sweet spot to allow rear facing. Great find as that doubles your seating when camping. How about a post mounted table between them?
Laissez les bon temps rouler!
[emoji604]
Old 12-15-2020, 04:35 PM   #77
campism's Avatar
Found that out right away. Test-fitted the first one before painting the pedestal just to make sure it would be worth the trouble. Put it on the passenger side first and that was wrong so moved it left. I could drive it as is but would like more seat height and more leg extension, and I should be able to fix both of those with little trouble.
Swiveling means getting the armrests up and the seatback leaned forward, then swivel. When backwards it has a bit too much forward tilt but camping beverages might skew my perception of that problem.
Old 12-16-2020, 07:58 AM   #78
Pntyrmvr's Avatar
Camping beverages. I will steal that phrase.
Thank you.
Old 12-16-2020, 11:22 AM   #79
campism's Avatar
Here's the passenger seat slid all the way back, as it is most likely to be used. Allows passage past the doghouse and the right armrest clears the door armrest but the seat interferes with easy in- and egress through the side doors. It would need to be slid forward to improve that, and also for swiveling.
Driver's seat fully reclined with the dog's seat spaced back to allow that. Way too much space wasted on a setup unlikely to be used once a bed is in the van.
Here's the third pedestal that is stenciled "Universal" and this one is only tacked down in the van for now. It's secure enough for the dog to ride on but will be bolted in place later when its position is finalized.
This seat position makes more sense for us; the dog can squeeze in and it leaves us more build space behind it.
Our new home! They'll be removed again for upholstery cleaning, pedestal painting and lubing, and so I can rip out the old flooring for the start of the interior work. The driver's seat will likely get washers under the swivel base and under the mounts for the seat rails on top of the swivel base (looking for +1"), and I'll try to mount those rails more rearward, all for more legroom.
The bride is interested in trying out the single-armrest grey buckets in the Coachmen van still in the junkyard. I'm going back for some more interior pieces and some other junk so we can test them, but I suspect that their mounting bolt spacing is similar to the stockers and they won't fit the swivels without too much work. For that much effort I'd want better seats but I wouldn't be as picky about bolt-ins.
Old 12-16-2020, 12:55 PM   #80
Pntyrmvr's Avatar
Interesting sight on those buckets. They might be from a position further back in a van as they have both armrests. Most conversions only use the inner armrests and rely on the factory door armrest for outer armrest.
Eliminating the outer armrest helps move both driver and passenger closer to the doors. Driver more at steering wheel center and passenger legs further from doghouse.
I had to figure all this out to put a console/bench setup in mine.Click image for larger version
ID:	37481Click image for larger version
ID:	37482Click image for larger version
